Another little project - I was thinking of doing a cluster swap, as i have an intermittent fault with mine The clusters are a plug and play swap with the 17 onwards with the mid are so much cleaner   Even tho the cluster is plug and play there are 3 issues 1. The mileage needs to be corrected This one is fairly easy to overcome after a fair bit of digging i found the information required, The cluster needs to be read with a programmer luckily it uses the same
