2008 Auris Air Vent
Wilf58
Any suggestions on how to remove the drivers-side Dasboard air-vent ? The slider portion has broken off and some of it is lying inside the vent. does the ENTIRE 😲 dash have to come out ?
According to this listing, it looks like there are screws from the inside.
https://www.ebay.co.uk/itm/TOYOTA-AURIS-DRIVER-SIDE-FRONT-DASH-AIR-VENT-2006-2007-2008-2009-2010-A1-309/283109611182
Taking the dash out is not such a hard thing to do, had to replace power steering module so i took mine apart in under an hour.
You can check out my topic, i put some pdf and tips in there, should be helpfull if you were to remove it.
The trickiest part was removal of A pillar covers, as it has airbargs stored there, you just need long needle nose pliers to twist the tab so the cover can come out, and it's nothing hard, the rest is just unscrew few bolts here and there.
image.thumb.png.060b4771623dfe0cfdfbc74b1fb24eea.png.
Bit of a long shot, try sucking them out with an attachment on a vacuum cleaner.
