Carpet for 3 door t sport 2002
corradovr6
Is a replacement carpet available for the Mk1 3 door at all?  Been looking on eBay etc and i can only see floor mats.  Presumably it will be just a Toyota item.  Mine has a cut from previous owners - not removed it as yet but i thought if a new carpet is not too pricey its worth just swopping the old one out.
Toyota will have discontinued the item 15+ years ago there is nothing special about the T sport carpet its a 3 door xp10 Shell (Jap built)
if you could find one, NOS, it will be in the £4-500 range
Proper automotive carpet is not cheap, you will need to use yours as a template or buy a used item
https://www.woolies-trim.co.uk/
Oem carpet depends on the build date
05/2001 - 12/2002    58510-5C570-B1
12/2002 - 08/2005    58510-5C260-B1
Nos from japan - $660 + shipping + duty + tax
Great info Flash, thanks. At that price its worth just repairing!
Is there much difference in the rear carpet between the 3 and 5 door models as most of those listed on eBay mention they're for the 5 door?
There are different versions - yes the 3 and 5 door are different also make sure it's a Jap built car if it just needs a clean take it out, steam clean, carpet cleaner (rug doctor) or scrub and pressure wash it then hang it up to dry
Called Toyota today.  Had to sit down for the price - £750+VAT and made to order.
Mine has a hole worn in it, in a pretty strange position along the tunnel under the gearstick, so its in a vertical position.  I'm thinking of some method to patch it that doesn't look like a patchwork quilt.  The insulation has also worn through and the carpet itself looks like its stretched.  Insulation wont be an issue and the carpet could be reinforced from behind, and i suppose i could put some kind of 'dead pedal' plate on it.
Welcome any suggestions.
The only other thing you might be able to do is get one from a wrecked T-Sport in a breaker's yard, but you'd probably have to ring round a few and get lucky as they don't usually salvage the actual carpets before crushing the cars...!
Even if you do it will likely need a real good clean...
agreed - just dropped a few suppliers a request, but its certainly the sort of thing to look at before buying.
You're not wrong about the clean!
  • Haha 1
Actually I'm thinking of cutting a piece from a hidden part of the carpet and sticking it in place - similar to a leather seat repair..might work...
