Toyota c-hr windscreen seals
Hi!
I just had my toyota c-hr for month and a half and today i noticed a difference between left and right windscreen corner seals. Should there be a little hole in the middle of the other one.. other one in sealed all the way, but on the other hand theres holes on that side where water can go. Its really not a seal but maybe correct name would be cover..
this does not look like a hole for water drainage but more like a dent in the seal, it should look like the one on the other side. If you can have some plastic tool to,take it out and you will be alright. 👍
Yes , it was very easy to take it out, but due to time it has been that way the rubber is permanently dented that way and it makes it worse if taken out. So i leave it like it was untill i get replacement part from toyota.  All and all it doesn’t matter so much cause water goes there anyway.. thx for answer 👍
