Interior lights alternately working
Aharon
Hello Folks,
I have a very strange issue,the interior driver light are not working when the car park in the garage or after a night , but after i park the car outside in the sun (Israel is hot) they start working and when the temperature goes down again they stop working feels like contacts problem.
Did someone had a similar problem and able to assist?
Take it out and check the contacts. When it's cold, and does not work, try to wigle the light, to see if it turns on. Ideally check the connections to see if the car sends the power to it or not.
If it does not work automatically, and you enable it manually via switch, does it light up then?
