Driver mirror closing more than passenger one?
IQ fanatic
Hey guys, I have a toyota iq 2009 model 1000cc and I noticed that driver side mirror closes more and a bit slower than the passenger side. I have to mention that there is no problem with the functionality . I cannot find any photos on google to compare..
Here are the images: Any help
probably just needs lubrication...and then let it run for a few cycles.
Ah sure , I will handle it. About the end position ? Do you think it is a problem? No sounds or noises though
It looks like it's been hit at some point, with it folded gentle give it a push, It should click
push towards the outer side , I guess you mean.  Ok thanx flash
push it inwards with it closed, someone clipped my mirror on the Yaris, I had the same issue
