Corollians,
I am facing an issue with the rear Speakers of my corolla 2016 gcc specs. Actually when i bought the car it has this rattling noise and when i checked i could see crack on the Speakers. Now, after replacing the Speakers with a Rockford 6*9 i could notice the same rattling noise from the back. Have anyone experienced this before. I felt that it was a waste of money in changing it. Is there any solutions?
Regards,
Nikhil
Must assume that it only rattles when the Speakers are in use ?
If having changed the Speakers, what about the mounting screws/rivets or cables  are they all fully tight and no movement.
If the Speakers were causing a rattle, usually the bass sound, look and tap  around the area inside the door/body  cavity where the speakers are mounted to see if anything makes that rattling sound.
