T27 Aircondition controller replace nordic to european
zaslepenec
My climate control knob is not working, according to the forum (https://www.toyotaownersclub.com/forums/topic/179512-t27-heateraircon-control-malfunction/?_fromLogin=1 ) it is probably a faulty potentiometer.
I would solve it by replacing the panel (from the used part shop (from wrecked cars)) but I have a "Nordic" edition with a special button for heating (type 55900 05310 - https://www.varaosahaku.fi/fi-fi/Hae/Osat/Tuotenumero/55900-05310/  or https://www.bildelsbasen.se/sv-se/pb/Sök/Bildelar/s1/Toyota/TOYOTA-AVENSIS/2009_2015/EL-&-Givare-&-Databox-&-Sensor/AC-Styrenhet-&-Manöverenhet/Alla/ID-40257693/55900
My Toyota Avensis T27 was  bought in Sweden.
In our country is available only normal European edition without this button (type 55900 - 05320
https://www.toyota-dily.cz/www-toyotavrakoviste-cz/eshop/1-1-Avensis/63-2-2009-2012-T27/5/4105-Ovladani-klimatizacehttps://www.toyota-dily.cz/www-toyotavrakoviste-cz/eshop/1-1-Avensis/63-2-2009-2012-T27/5/4105-Ovladani-klimatizace
A new panel of the Nordic edition in an authorized service station costs 2x more than from a Swedish scrapyard (used part shop)and 4x more than the "European" one from a local scrapyard (used part shop). I don't insist on a special heater, so I would like to ask if the "Nordic" and "European" versions are interchangeable, so I can easily swap the Nordic for the European and save money.
Thank you for the answer
I cannot answer your question regarding getting the more cheaper unit, but if the problem is the temperature control knob, I did my own fix a few years back -
I dismantled, cleaned, adjusted and re-assembled the unit. It has worked fine since.
