2012 T27 estate rear bumper removal
rob42
folks, recently there was damage done to the rear bumper of avensis including the reversing light lens, I haven't had a good look on how its held on yet, but just asking has anyone any experience? how involved is it? it'll have to be removed to be repaired, but i may have found a bumper in a breakers about two hours away which may be the cheapest and easiest option. And might do a hot swap there myself in the chance it wont go in the boot.
Cheers, photo of damage to come.
Years ago I slackened/removed the bumper of a T27 saloon to fit reversing sensors and wiring.  I can't exactly remember the procedure but IIRC you undo the wheel arch liners, remove a large bolt at each side at the boot ingo, and remove a bolt or two under the centre.  Can't remember whether the edges pull out sideways or the whole bumper pulls off backwards.
I would have thought that a good SMART repairer could do that on the car?
Shame about the light lens.  😞
Yes but photo doesn't show well that there is a crack completely through at the crash bar support so I'd imagine it'll need to be manipulated on both sides??
https://www.toyota-tech.eu/aimuploads/{2DB34D7D-78C9-0BA2-1642-C79ACAE678C9}/PZ408-T5556-00 Avensis Wagon Detachable hitch PZ408-T5556-00 AIM_001_269_5.pdf
Bumber removal starts at page 15.
Page 18 shows that You have to only pull bumber to backwards but I had to pull edges behind to wheel a little bit sideways before to pull it backwards.
thank you
Hi
Apparently it's really simple, my son removed the rear bumper on our saloon version in under 5 minutes, he was showing off, reason for removal we intended to install lower led lights where the reflectors sit until we realised it was impossible due to a rear lower bodykit skirt in the way.
Wishing you the best of luck with your repair. Get it fixed or it'll bug you!
