Central locking works with fob but not spare key
SuperCoolDude
I see lots of topics about central locking not working due to the fob Battery needing replaced or wiring or fuses needing replaced - but not for this case.
In my case central locking on our 2008 Yaris works fine with the fob; but with the spare key in the driver door, only the driver's door is unlocked. It didn't previously do this, only recently has the physical key stopped working with central locking.
Is there a setting for this we accidently set? Or possibly a specific fuse/wire for central locking being driven from the keyhole?
That's a facility on mine. It's a means of unlocking just the driver's door to prevent any undesirables jumping in when you unlock all doors.
Do you know how to turn it off and centrally unlock all the doors again please?
So it turns out that a single key turn unlocks only the driver door; two turns centrally unlocks. I'm fairly certain I previously never needed to do this, and maybe there's a switch for this somewhere, but I could just be mistaken...
Well I never knew that! That's the advantage of a forum like this, you learn something new. I don't know of any method of changing the facility.
