When Should The Timing Chain Be Replaced On A 1.8 Toyota Avensis 2007?
dilligaf_76
Can anyone tell me when a timing chain should be replaced on a 1.8 Petrol Toyota Avensis 2007?
Normally it shouldn't ever need to be replaced, there is no regular interval for replacement. It's only if there is a particular fault, eg it becomes noisy that it would need replacing.
  • Like 3
A Kevin ***** Wilson fan ?
With regular quality oil changes, It should out last the body of the car
Yup, Toyota did chain-driven cams correctly, unlike certain other marques *coughBMW* *coughTheFrench*
  • Haha 1
  • 4 weeks later...
It's a good idea to check that the chain tensioner is not blocked or damaged.
A timing chain is often too slack after 400tkm
Apparently, those on the Honda accord can loosen a tad over time as well.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
