Toyota Prius Gen3 - Electric Power Steering
Monstrobolaxa
I am working on a project that is looking to install an electric power steering to another vehicle. I have come across the Prius Gen3 electric power steering that has a fail-safe mode, i.e., if the steering control unit is unplugged the power steering carries on working at a given load, independent of the vehicle speed. On the Gen2 Yaris there is a similar system, but it requires the vehicle speed signal to be life for it to go into the fail-safe without the motor control unit.
Now the question is, does anyone know if the Gen4 Prius electric power steering has the same fail-function function? If not what are the differences? And does anyone have the pin-outs for the power steering connectors?
Thank you for the help.
Hello flash22, Thanks for the reply.
I had seen the 1st link you've shared...I was just wondering if the fail-safe is still present in the Gen4 as the used ones found on ebay/parts breakers are likely to be lower mileage.
It will go to fail-safe if the torque sensor and steering angle sensors are not seen by the ecu iirc these can be bypassed, i did look into this many years ago for a friend
Ok cool. That helps.
Basically looking at running an EPAS in fail-safe mode with the control unit disconnected....R&D project.
Just looked at the later 15 on specs, the fail-safe either reduces assist or turns the eps off completely
It looks like after 2009 they changed the fail-safe, if the ecu doesn't see the angle or position it turns off
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
