Auris fender liner clips?
itte
Is there picture of fender liner clips and partnumbers?
Maybe I can get them from eBay de because toyotas prices are awful, over one euro piece.
You can buy non original for much lower price , all you need to know is the size and shape then look at eBay Toyota clips and you have plenty to choose. This side can you can search for your car get the part number and check in google for pictures and sizes https://japancars.ru/index.php?route=catalog/toyota 👍
I just got something like this:
https://www.ebay.co.uk/itm/143853997666
Nearly every kind of clip imaginable - If it doesn't have the exact one there's probably one close enough.
Keep lending it to friends who need replacement clips and we've still barely made a dent in it :laugh:
Get original clips, eBay clips are not good, often  break so easily and in fender or underbody is not a good idea. You can use eBay clips for interior.
I have a similar selection box (not chocolates) as Cyker for the same auction site. They are specifically for Toyotas. I've used them, for example, to replace those securing the underside of the front bumper moulding and the access panel for the front fog lights. That was about 5 years ago. No issues with breakage or being affected in that exposed place.
Also had to replace the "push rivets", on the underside of the rear bumper moulding, from the same set. In fact they are more durable than the originals which were in very poor condition.
  • Haha 1
Some eBay clips are good, not the cheapest one though, I usually buy exact size and shake like 10 for £3-4, and never had any issues.
Thanks guys, you are right. Some clips on eBay are OK, but I had once that is really bad, break everytime I open it, kind of one time use.  Toyota clips for the oil pan are durable, I only break clips  when changing the transmission fluid. They are very tough to be removed from dirt and sands.
