Exhaust catalytic converter t2-t3?
Xrpaul
Hi does anyone know if the toyota avensis t3 1.8 petrol uses the same exhaust/catalytic converter as t2?? cheers
1.8 is a 1.8, the grade (spec) has nothing to do with the engine/emissions use your vin or reg to find out what engine you have it should be the 1ZZ-FE (129 bhp)
Hatch, saloon or estate ? do you know your model code ? eg. ZZT250 (one piece secondary cat and Mid-silencer), ZZT251 (2 piece secondary cat and silencer)
Primary CAT (part of the manifold that has the sensors ) or secondary in the Mid pipe ?
http://www.euroflo.co.uk/Catalogue.aspx
