Fog Lights & Stalk
Darranluck
Just joined as a member and not sure if i'm posting this in the right place etc. I bought a 2018 Proace a few weeks ago,  it doesn't have the front fog lights fitted so i bought the proper toyota ones and new indicator stalk with front fog light switch built in. I would like to ask if they will simply be plug and play once wired up or will i need to get ecu programmed etc? Thank you.
