Hi,  new here, and new to Toyota (my wife's car actually).
We have a 2006 Corolla 1.6 with around 120k miles that has starting flickering the oil light on idle, from time to time.
The idle is high when it starts from cold (1800-2000) but i'm told this is normal for these and it settles fairly quickly. However when it is warm the idle is sometimes what i would consider very low to the point it sounds like its struggling. It goes up and down (not in a hunting way, maybe 800rpm for 30 seconds and then 600rpm for 30 seconds or so, repeated) This is actually slightly higher with the AC on (i assume something compensates for the extra load and  puts in more fuel or something) but still feels like it is going to stall from time to time.
Yesterday the oil light flickered a bit when the rpm was at its lowest, and then goes out when the revs come back up again. Never comes on whilst driving, just when its idling and only (for now) whilst its at its lowest idle level.
It's been serviced in the last 6 months, and i've checked the oil level which is still at max on the dipstick.
No faults logged, and it otherwise runs absolutely fine.
Before i just take it and say "please fix" are there any common things to look for, and is the low idle likely to be related and just simply too low for the pump to keep the pressure up so fixing that might fix the oil pressure issue?
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
