Backup Camera
wizwend
We have 2021 XSE Hybrid RAV4, in Florida. When the weather is hot (which is 95% of the time) the back up camera freezes and or shakes. Any suggestions on the cause. Only happens when the weather is hot. TIA!
Take it back to the dealer, more than likely the camera needs replacing due to moisture - Florida is extremely humid
best thing you can do is video the issue,  it gives you something you can use as proof
As flash says it is most likely due to humidity. Something getting wet in the electronics or wiring.
