Upgrading Satnav software/maps
sproutdreamer
The satnav info on my 08 Avensis is very outdated now and I wish to update it. I see 2017 discs available that appear to fit the bill but is there anything I should be aware of either the compatibility of these discs or the actual upgrading procedure i.e. just bung in the disc or more than that?
Advice on this is welcomed.
having had a look on eBay I see that you can allegedly get a 2021 update disc for a TNS700 (which is what I presume that you have). I say allegedly because it will almost certainly be a counterfeit, cracked disc rather than an official Toyota but equally it will probably work.
I had the disc out to confirm what software issue it was-now the disc will not go back in. Any ideas?
you are putting it in the right slot?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
