ignition "logic" change for radio/buzzer?
Electronic Battle
Hello all
(1) My 65 Yaris Icon needs to have the ignition key in and switched to the first position ("accessory" I suppose) to power the head unit. Is there a (.hidden) menu option to change the logic so that the head unit can be switched on and off without needing the ignition key in this way?
(2) If the key is in the ignition and I open a door, I get a continuous warning buzzer which goes away once the door is closed. Similarly, can it too be menu disabled?
1. No
2.yes, the key reminder can be turned off with techstream or one of the many dongle obd2 scanners like Carista (Pay to play app)
Excellent Bob - thanks! I will look into "techstream"  and co. in greater detail for point (2). Interesting!
