Prius 17" space saver wheel fitment
Silver Yaris
Hi all, I am looking for a 17" space saver wheel 114.3x5 with a centre bore 60.1mm and was told that the Prius possibly has this fitment.
Is anyone able to confirm?
TIA for any responses.
don't know about  Prius (but I suspect that it is) but I have one from an Avensis that should also be 5x 114.3, 60.1mm bore - yours foc if you can arrange uplift.
Tyre will be out of date.
this size it’s not for standard Prius but avensis and Auris and Prius plus 7 seater only.
2 minutes ago, TonyHSD said:
Perfect - that makes sense. Thank you
You are welcome. Here you can use this website to locate the different sizes of different makes and models. 👍
https://www.wheel-size.com
Unfortunately for me, I am trying to use the fitment (from what I now know is an Avensis & Auris) on my other Toyota that didn't come with a space saver, just the pointless gunk / tyre weld.  After destroying a tyre last weekend and the gunk not working, I need a space saver.
Hi Scott, I need a jack & toolkit too and would need to replace the tyre so I will leave it, but thank you for your offer.
Fairly sure that I have a jack too, same goes should you wish.
The toolkit is a wheel nut socket wrench. 😉
Scott, I will message you.
  • 4 months later...
Hi new to the Prius club.
it’s my wife’s car I’m also looking for a spare wheel space saver.
Seen the wheel shop in Manchester says that the 2003 to present day wheel they have fits the gen 4.
is this right.
thanks for any help.
is this right.
you can use this website to find your model and then other models to compare wheels sizes etc and see if it will fit. 👍
Thank you TONY.
handy site that is for plenty off information on it.
also I had sent an email to the wheel shop Manchester and they  have confirmed that the space saver they have will fit the Gen4.
purchased at wheel for a C-HR  from them before which fit perfect also.
