Auris 2013 1.6 boot split floor into a 2017 1.2T - is it possible?
ATF1979
Hi all,
New member first post!
I did have a 13 reg 1.6 petrol which had a really useful split floor in the boot, but I have just bought  a 17 reg 1.2 and was surprised to see that the facelift does not have the same boot arrangement.
Is it possible to get hold of the complete sub floor from a pre-facelift and will it fit into a 17 reg?
And, anyone know why Toyota dropped it in the facelift cars?
cheers, Steve.
Isn't it an adjustable deck board, meaning you move it from the lower level to the higher level ? If you have it, it will have a lifting tab on it
58410-02050-C0
Nope, no deck board and no side supports for one - the pre-facelift had these, the facelift does not.
The board is listed up to 18, 1.2T is an entry-level car so may not have come with the option, the Yaris is the same you have to replace the interior trims to fit the board on the lower spec, smaller engined cars
