Dash cam wiring & hi
Hi, firstly I would like to say hi.
All being well I am picking up my 67 plate Nebula blue Dynamic on Saturday. Will be bit of a change from the manual BMW M140i it is replacing. Will certainly be more relaxing, comfortable & economical!
First job will be wiring in my dash cam. Any pointers as to where to pickup up an ignition or accessory feed?
Many thanks
Andy
Hi Andy,
I paid someone to fit our Dashcam in the C-HR, but watched how they did it. They ran the cable down behind the A pillar trim on the passenger side and into the fusebox below the glovebox, then used a piggyback fuseholder onto the fuse which supplies the steering lock & immobiliser.
Thank you. Will look there 1st.
Picking my C-HR tomorrow morning.
I used the fuse slot rated at 15amp that is used for the power outlet in the centre armrest.
This is located in passenger side footwell.
Used a breakout fuse.
Earth was a ring terminal under a 10mm nut above fuse box.
I also have a rear camera, so ran lead under trim to tailgate and through right hand cable grommet as it was empty.
Easiest dash cam install I’ve ever done.
