Hi All, I am new to this fantastic Yaris forum so pls take it easy on me 😀.
I bought the new Yaris excel hybrid mk4 2020 and managed to loose/misplace the fuse layout and details paper which is inside the passenger side fuse box. I have looked everywhere for it and can’t find it. Can anyone owning same model car as me take a picture and share it?  That would be most appreciated.  Thanks
Is it not covered in your owners manual?
If you have the abbreviated manual, the full manual can be downloaded from - https://www.toyota.co.uk/tme#/my-toyota/eManual
He's saying he's lost it - If it was an ex-demo car he bought, he may be a victim of the whole removed Dashcam stupidness someone was complaining about in another thread, where they used a piggyback fuse to power the Dashcam, which prevents the lid going back on the fusebox, so they leave it off or cable-tie it to to something, but didn't bother putting it back when the Dashcam was removed prior to sale.
I have a dash cam piggybacked into ‘P/OUTLET NO.1 (15A)
Hi All, thank you so much for all the replies.  I have already downloaded the manual and as rightly said it does not have low level details of each fuse and function. The back of the fuse lid has some details but they might as well be encrypted as without the paper which normally is inside the lid (which i have misplaced) has the real details i.e. usb ports,  lighter, internal lights etc.  And you are right the reason why i lost the fuse paper is because i too installed a dash cam and piggybacked into one of the 15A fuse and absolutely right i too can't put the lid back on 😞.  Now i am in pickle as i recently added few LEDs to the passenger, driver, middle console and front doors and some how managed to blow a fuse somewhere that's stopping them from coming on, everything else is fine.   Not sure if anyone has a copy of the paper that was inside the fuse lid that has the details of each fuse. (or i am going mad and dreamt up this paper with all the details) 🙂
Problem solved, managed to find an old multimeter and checked all the fuses (using resistance/continuity beep), they were all fine.
So, looks like something else is stopping the ambiance lights from working.  Will have strip it all the lights out incase there is bad connection.
  • 1 year later...
Which fuse is for the washer please
  • 1 year later...
Hello everyone,
Looking for some advice regarding how to hardwire a Nextbase dash cam, into my wife's newly acquired 2022 Yaris. Cjohnson has a great photo of the fuse box cover (in his post 8th October 2021), located beneath the passenger glove box, and has used the fuse "P/OUTLET NO 1 (15A). Is that amperage a little high and would it be safer to use either USB NO 1 (7.5A) or the even lower rated, DCM (5A). However, I don't know what DCM means and would hate to use it, only to find out that I have tapped into something really important.
I am going to use a Low Profile Mini Fuse Tap (piggy back fuse holder) to get power to the dash cam. Any advice would be much appreciated, particularly from flash 22
Kind regards, Bob Sutton.
You’re confusing the fuse rating that you’re piggybacking and the fuse rating for the Dashcam.
Just use a lower rated fuse (5A) in the piggyback connector and leave the 15A fuse in the original connector.
a fuse tap holds 2 fuses - 1 for the original circuit and the other for the "tap", don't over think it
Hello Graham47 and flash22,
Thanks very much for your reply and information. If I understand it correctly, in the annotated screenshot attached below, would be where each of the two fuses would go, if I used the 15amp P/OUTLET NO 1, as Cjohnson1982 did in his post dated 8th October 2021. Could you please confirm if that is correct and the right way round.
Thanks again and kind regards, Bob Sutton.
Yes that's correct.
The simplest way to remember is just to look at the tail coming out of the fuse holder. It leads directly into the top fuse position hence it's logical that this is where the fuse for the new accessory should go
On 2/1/2024 at 9:00 PM, Dick_Dastardly said:
Yes that's correct.
Hello Dick_Dastardly,
Thanks very much for your advice and input.
Does anyone have any idea what DMC stands for on the fuse box cover located beneath the passenger glove box.
King regards, Bob Sutton.
DCM - Data communications module - it's a glorified mobile phone that lets the car talk to the mothership (Toyota) and perform SOS calls in the event of an accident
Hello Bob,
Thanks for that clarification.
When using a piggy back fuse it's important to ensure you insert it into the fuse box the correct way round.
The side nearest the tail is the "load" and the side furthest from the tail is the "supply"
For any given fusebox pair of slots one of them will show 12v when connected to a multimeter, and the other will not show a reading as it takes the current away to earth.
The "supply" side of the fuse holder should be inserted into the socket showing 12v.
If you put them in the wrong way round then the accessory will still power on, and you'll be fooled into thinking everything is fine. However, if the fuse needs to blow to protect the accessory then the current may take a circuitous route through the other fuse or may not blow at all.
You could also find that the tail lead has power even if no fuse is present, which is a sure sign that something is wrong and the circuit will not protect you as you hoped
There's a video here explaining things
https://youtu.be/8b9CvUMcNQo?si=PfBGzOag9qA8gQ5H
Hello Graham, thanks for the 'heads up' on the possibility of getting the piggy back fuse holder the wrong way round, therefore, not protecting the dash cam, also the link to the YouTube footage.
If I remember correctly, from my previous research on this issue, I think I've heard the "supply" side being called the "hot" or 'live" side. I do have a multimeter, so I will use it to check which side, is which.
I have attached a rough (very rough) hand drawn layout, I which hopefully, is the correct interpretation of what's required. Could you please let me know if this is correct.
Diagram seems spot on.
Obviously the lowest fuse you can get away with is the one to go for. Whilst a 5amp will "work" in the sense that it will provide power to the dash cam it may not necessarily be the weakest link in the circuit so a 2 or 3 amp will provide better protection
My Dashcam draws less than 0.5 amp so next time I fit it I'm going to see if I can get away with a 1amp fuse. Might be a bit low so if it keeps blowing then I'll go up to 2 amp. 5amp will be way too high
My dashcam draws less than 0.5 amp so next time I fit it I'm going to see if I can get away with a 1amp fuse. Might be a bit low so if it keeps blowing then I'll go up to 2 amp. 5amp will be way too high
Hello Graham, thanks for your reply. I think 2amp is the lowest fuse I have. Thanks for all your input and advice.
Pleasure
  • 2 months later...
Use as small a fuse rating as you can, but remember the fuse is there to protect the cable NOT the device. A lot of people don't understand this.
  • 4 months later...
Just joined having come across this topic whilst trying to work out a power source for my camera and I very much enjoyed your contributions. Even downloaded the manual.   Can I add an extra dimension to this topic?
My Yaris hybrid was purchased new in 2023 and as I already had a home installed Nextbase camera in my trade in, the dealership offered a comparative setup.  I agreed and I have the Nextbase 380 front and rear.  Unfortunately, in my eyes, they’ve only connected it to a switched live fuse so when the tiny internal back up Battery runs down the thing shuts off.  Consequently any collision whilst unattended for any length of time isn’t recorded.  On my Aygo I had it connected to the OBD port so it was permanently ‘on’ till it registered a low voltage.  I’m pretty sure I asked for the same yet recall some comment about it being unwise or even impossible it being a hybrid!   Personally I don’t see why.  Sorry it’s been a long introduction but the question really is just what, if any, problems could occur by using (in this case the Nextbase) OBD hardwire accessory cable?   It does of course register an increase in current on engine ignition so starts immediate continuous recording and switches the camera off when it detects a low current.   Thank you.
I seem to recall people adding there own power supply / Battery pack for extending its operating time without pulling down main car 12 volt Battery.
