Hi all
Ive noticed damp in the boot of the Estima. Looked under the car and noticed a plastic plug missing from one hole meaning water can come in from underneath.  Any idea where I could get a replacement or a hack to plug it??
I would suggest this has been removed to allow water to escape.
Hi Paul. Do you think this was meant to be permanent for some reason and someone forgot to replace it?
One car I had had a split plug. A small rubber stopped 'pipe' protruded from the hole.  It was split down the sides and across the bottom.  Water could not get in but it could drip out.  Was it a plug like that that is missing?
I suspect the plug should be fitted and that you will, unfortunately, either need to locate source of leak or live with it. Liking with it would mean regularly steamed up Windows!
ok thx guys. All helpful stuff
