Toyota Touch 2 Pinout
4apai
I have a Toyota Yaris 2015 , it had a Toyota Touch 2 (Fujitsu Ten 86140-0D100). I’d like to replace it.
I’m looking for pinout description.
Why do you need a pin out ? Don't go hacking up the factory wiring when the adapters/leads are available cheaply
what are you looking to replacing it with - avoid Chinese junk from the likes of Amazon, eBay or AliExpress you're just wasting your money
I've already bought. I need to add 6v to the 2nd pin of connector 28p
28 pin connector - pin 2 is the reverse signal TO the radio, the Yaris doesn't have a reverse signal as it uses canbus
what are you trying to do ? If you are trying to use the factory reverse camera, you will require a camera retention lead
CAM-TY2-RT
The Touch2 supplies the 5-7v (6v Nom.) TO the camera
For the reverse signal (12v)......................
The reverse wire runs from the rear of the car on the drivers side (LHD) or passenger side (RHD) in the body loom up the firewall and into the fuse box, it does not go through the connectors behind the drivers (lhd) or Passenger (RHD) kick panel
The wire colour is red you can track it down using a wire piercing probe or tap it in the fuse box
Pin 19 on BA1 - Verify with a multimeter that you have 12V in reverse
View of the plug is from the front (Left)
View of the socket as are looking at it (Right)
Pin 2 would be for a reverse signal (28 pin)
the 6v for the camera is supplied from the touch 2 (It's an Output)
the camera is on the 24 pin 2014-2020
You can use pin 24 as a ground
thank you very much.  it would be better to return the multimedia.
