I’m looking at installing a rear “dash” cam to my 1.8 TS. It will need both accessory and permanent feeds. Does anyone know if there is an accessible permanent feed in the luggage compartment area? I can easily tap off the 12 socket for the accessory feed.
Hi the 12v power socket is not a permanent live feed. You need to tap to fuse box underneath the glove box most people use piggyback fuses. But if use piggyback fuses the cover to fuse box will not fit
Thanks - I’ve already installed the front camera and used a piggyback on the fuse box for both feeds. I was really just asking if anyone knew of a more easily accessible permanent feed in the rear of the car rather than running a wire all the way through.
