Front screen fan not blowing
Steven83
Hi guys. Thanks for all the help the past few days with my many questions.
i think my car my have an issue with the fan.
I tried the button for the front screen de-mister today and the fan speed increases as does the air flow to my feet but absolutely nothing, not even a breeze comes out of windscreen or side window vents.
is this something you have come across before? Can’t believe I might need to get it in to be worked on the day after I’ve collected it.
have you try to change the blow settings, make the air flow goes towards windscreen and feet (up and bottom), try with AC on and with AC off and see if that makes any difference. A short video may also help us determine your problem. 👍
1 hour ago, TonyHSD said:
Hi tony.
Yes I tried all the possible combinations and I couldn’t get anything out of those windscreen vents at all 🤷‍♂️
I’ll try again tomorrow and see if it was just having a bad day but it certainly didn’t work how i would expect it to.
