Electric handbrake problem
daveadar
Hi, I have a problem with my electric handbrake on my 2015 Avensis estate.
It is an intermittent fault. Some times when you switch off the car the handbrake will not apply automatically, or it won't apply by using the switch either.
There is no alarm or warning on the display, just a message saying to check that the handbrake is applied.
Has anyone had this issue, I know the earlier models had an issue with the actuator, but Toyota tell me there have not been the same problems with the 2015 model.
i had this problem if when i turn off the car and its still rolling to a stop sometimes i know where the car is going and turn off the car before coming to a complete stop then the automatic handbreak wont switch it on then will show up on the dash saying the handbreak not on
Thanks for that. It has not happened to my car for a while but I'll watch out for that.
