98 RAV4 Water Penetration through Sunroof
Beardieman
Has anyone any details on the drainage system from the sunroof? I have got water entering my 98 RAV4 through the sunroof. It is running down inside the drivers side door/windscreen stanchion onto the junction box 1 / fuse box  and into the car. The sunroof drainage holes are clear, and am wondering if the drainage pipe has somehow become disconnected. I cannot find any diagrams anywhere as to the construction of the drainage system. Has anyone else come across this problem?
Problem solved. By easing down the headliner on the drivers side, after removing associated trims and sun visor, you can see the drainpipe for the sunroof. For some unknown reason the pipe had become disconnected from the sunroof drain. It was fairly easy to push the drainpipe and spring clip back onto the sunroof drain. Thanks for your support.
