At what temperature do you fit your winter tyres ?
marlinleg
When do you fit your winter tyres ?
Your thought please
Hello to everyone . 4/5 years ago I rang Dunlop tech department asking the question at what temperature to fit winter  tyres as there adverts were saying 7c and below
Dunlop's tech guy said quote " we told the idiots in advertising that's not right anything below 12c then fit them as you will benefit "  he went on to say they are cold weather tyres but have the advantage of being good in the snow. First and foremost they are a cold weather tyre, shorter stopping distance
Take care everyone
Given many countries require them fitting by law from end of October I would go by that rule of thumb. I use all weather tyres, saves the hassle.
  • Like 3
Hi......where does nitrogen gas fit into this ?
I was under the impression that tyres inflated with nitrogen gas provide a wider window.
Less affected by higher/lower ambient temperatures.
 Need to know what a new car's come with these days.
Barry Wright Lancashire.
Yup, 1st November used to be my rule of thumb. You can get through October OK on summer rubber, but one day in the next month or so you're likely to meet weather that warrants winters. If you try to go by temperature you are almost certain to leave it too late. Winters 1/11 - 1/5, summers 1/5 - 1/11 ...
That's a good idea, but be aware that not all "All weather" tyres are certified for snow conditions. They must have the 3PMSF logo (A mountain symbol with a snow flake in it). There's a snow tyre mandate for just about everywhere around where I live, mine are going on the car in a few days.
You use it to inflate the tyres.... Ba Dum Tsh!
When I looked at getting winter tyres some years back, the main arguments for them were about the tyre itself, the rubber compounds used for the winter tyres being designed to remain soft and flexible at lower temperatures to provide more grip when cold, combined with different tread patterns better designed to cope with winter conditions, snow, slush etc. The fill gas doesn't affect any of this.
I thought the trouble with running winter tyres in the UK is because they are pretty rare, we don't have the same support services you get in those countries where they are mandatory, like easy purchases of steel rims for the winter tyres, tyre garages offering storage services so you don't have stacks of wheels cluttering up your garage at home for most of the year.
The nitrogen gas is to reduce tyre pressure leakage.  Although the air is nominally 80% nitrogen the 100% nitrogen is used by some companies as an additional feature, Costco uses nitrogen fill.
I only use winter snow approved all season tyres given we often drive into EUland in winter. If they do not have the above symbol then IMO they are not all weather tyres.
I swap them when the clocks change as it's an easy reminder, except in my RAV which I have on winter tyres all year round.
I ran winter tyres all year round on my 508 Hybrid. No problem at all. Grippy as hell but obviously wear a lot quicker, still got 20K out of them.
Agreed. Did once run winter tyres through into summer. They were a bit squirmy in really hot weather but otherwise perfectly ok.
Back in the old days the winter compounds were the only compound available so nearly all tyres ran all year long.  The only difference was the tyre pattern.
I like the look of the CrossClimate 2 tyres, the ones specified as the OEM tyre by Volvo 235/55 R19 would fit my PHEV.
I've now done 30-35k on winter tyres all year round and they are at 5-6mm, I can't say I have noticed any longevity or grip deficiency running them in the summer.
Your thought please
Take care everyone
i use to change tyres b mid of november at first ocasion
cheers \ Igor
