Heater fault Toyota previa
2003 Toyota Previa heater will only blow cold air fluid levels correct engine temp normal heater hoses from engine to bulkhead hot the vents on the interior do not move when adjusting temp switch I’ve checked fuses under bonnet and behind the panels on the interior any advice please
Moved to the Estima forum.
