Accessories for 65 plate Toyota Aygo
Space saver, foam insert, rubber mounting blocks, jack, wheel brace and screw to hold down the space saver are available as a kit from the dealer.
I bought one last year, included everything.
£190
Anyone got the part number for a FULL SIZE 15" steel wheel for the Mk2 Aygo?
Mine came with a space saver but I want a full size spare.
Searched the internet but didn't find part number.
Saw this one on eBay :
https://www.ebay.co.uk/itm/281440695302
      It is expensive ..
We have some online second hand stores where you can find a normal wheel easily for a quart of the new price.
Unsure the full size wheel will fit your trunk space. Did so on an other brand and ended up with a wheel that was too wide , so
fitted too high in the spare wheel space of the trunk.
The full size wheel definitely fits diameter wise, and thickness once the thick spacer blocks underneath the space saver are removed and replaced with thinner ones (like on my previous Mk 1) it fits also.
Managed to get a full size spare wheel (described as a winter wheel) on eBay from a Toyota dealers shop.
Huh, I didn't even know the Aygo had a spare wheel!
If you want a full-sized steel rim, just buy one from a breakers yard and buy a tyre for it if it doesn't have one (Or even if it maybe buy one anyway, god knows what condition it'll be in!). The 4-stud pattern that Aygos use is very common, only tricky bit is things like offset and rim width, but I'm sure breakers will have the right ones. Could even just buy an actual wheel from a wrecked Aygo! :laugh:
That said, will a full-size one fit in an Aygo? In all the Yarises, the spare wheel bay is not deep enough for a full-width spare, so the boot floor would be resting on a full-sized wheel, or you'd need to get some inserts/spacers to raise the boot floor.
5 hours ago, Roger Cooper said:
There are a couple of 15 inch 'spacesaver' spare wheels / tyres on eBay, at 'fair' prices  ..................
As I said when I posted on this thread it's about a FULL SIZE steel wheel to use as a spare not about a space saver (I got one of them supplied with the car and want to replace it with a full size spare like my Mk 1 had).
I've got one now, from a Peugeot 108 (the same car as a Mk2 Aygo) - and been quoted for one from a Toyota dealer which they described as an Aygo winter wheel.
Yes, once you replace the thick rubber buffers under the wheel with the same thin ones as used on the Mk 1.
My brand new Aygo was delivered with 15 inch wheels, spare wheel is a 14 inch space saver.
Nice! :thumbsup: Can you post part numbers and costs or some such so other people after something similar can see?
Did anybody manage to find a decent flashlight that sticks or fits to the trunk (inside), preferably no 12V wired power but batteries / rechargeable ?
