Multi conector tail lights
Paddyspurs
Hi was working at tail light and the conector were wires go in i pulled them out now dont know were they go can anyone help auris 1.6 2007
You can check the connector and find the schematic for it, then reconnect the wires based on that.
Or if there is no schematic available, you can lookup the location of pins, and with multimeter identify each wire, then reconnect.
