My (2013 T27) seat is at the bottom and I'm still sitting too high
Mcfc1894
Not sure if there's anything else I can do, not sure I can get the "pump" to go any lower, seems stuck at the bottom but I might be wrong. I'm just over 180cm and while I find the seat is very comfortable I'd just like to sit a couple of inches lower. Anyone else have the same issue or do I just need more violence on the seat knob thing?
Are you sure you are operating the level correctly? Sorry if that is asking the obvious, it is just that I am a couple of cm taller than you and I actually prefer not having the seat at its lowest setting (2015 T27). So that perhaps suggests that you have not set the seat as low as it can go.
Are You sure there is nothing stuff under the seat wich blocks to set seat lower? I am 184 cm and I don't also have seat at lowest setting and I like to keep seat pretty low when driving.
Nothing underneath it and I'm pretty sure it's at the bottom. But reclining the chair just a little bit did the trick, plus raising the steering wheel slightly made it a bit more like what I'm used to.
Side note but I just got it, it's my first Toyota and I love it. Quite a lot of miles on it but still feels new and handles brilliantly. There's so much leg room which is brilliant, I've tried modern Volkswagens and Volvos of the same size and they don't come close.
