Injectors cleaned, car starts but won't rev
Desert technology
04 rav would never start only rarely especially when hot had a few things done,garage told me it needs  new injectors so at seeing the price I decided to clean them as I've done a few older engines and worked well, after pulling all 4 and cleaning re seating, sealing new fuel filter and rail cleaned all done turned the key once primed, fired straight up(SOLVED) but it's not once I jumped in touched the throttle it reved up ok then went lumpy and the throttle is non responsive dose the same once on and off  ANY ADVICE PLEASE, NEW TO RAV
to be inspected:
- glow plugs, as the first thing;
- engine air filter;
- EGR to be opened and cleaned;
- MAF sensor
check and revert / Igor
I'm concidering selling my rav 4 2004  silver, clean inside and out leather interior if anyone is interested as spares or repairs or breaking the as it now won't work after injector clean I've already had 2 injectors tested and have recipe there both fine haven't the time or funds, Durham area
Thats a shame, can I ask how did you clean the injectors out?
Thanks v much
Replaced the fuel filter ? Any codes, the SCV is common fail point
idles and won't rev - a blocked exhaust/ collapsed cat given its age drop the exhaust at the 2nd joint aka centre section
I removed the injectors wiped up with carb cleaner then cracked of the 14 mm nozzle end removed pins and springs use carb cleaner and a diy fitting to go in the nozzle and blasted through until all 6 pin holes were spraying mist re asembeled and now I've ended up spending 80 in the injector specialist shop getting them tested and all came back 100 % much to my surprise and I've checked exhaust and svc, Maf, a few other things aswell
Have you reinstalled them in the correct order they were taken out in? It’s an obvious question as the injector compensation values would need inputting if you got them the ring way round.
