Automatic Conversion
Effell
Hi everyone - New Member
Does anyone know of someone or any company that can mate an automatic box to a manual 2009 IQ2. And if so, what would be the approx cost of labour.
I don’t have the answer to your question but I am led to believe that automatic IQs fetch a premium over manual gear boxes, so maybe a solution would be to sell and buy a manual one - there are far more of these on the market than automatics?
The point which I somehow failed to put over is that whether it was possible for someone like myself with a Toyota IQ with a manual gearbox, providing I can source one, to have an automatic box mated to the 1 litre engine without too much modification.
I'm no expert, but I suspect it would be a massive job as you'd need to change so much stuff...
The ECU and engine loom will be different the flywheel will need swapping for a flex plate and torque convertor setup, drive shafts will be different as well, remove the clutch pedal and replace the brake with an auto one, replace the shifter and cables, the front brakes on an auto are usually larger too
Be aware the gearbox in the IQ is specific to the IQ as the diff and driveshafts are at the front
If you can find someone to do the work you will be looking upwards of £2500+, so sell the manual and buy an auto
