Is this touch 2 with go?
Steven83
Evening all.
is anyone able to tell me if this is a touch2 with go?
I would like to update it to a modern map. Is see there is an update on the myportal and it also seems to freshen up the whole software, but I don’t want to spend the money if it’s not compatible with mine.
the imagine below is my stereo.
Touch 2 was introduced into the Auris from May 2014, so, as your profile shows your Auris is a 2015 model, it should be the later multimedia unit.
Yes it is Touch 2 with Go, the latest version being 6.18.0WL for your car.
Thank you for the reply. Yes mine is a 2015 pre face lift so I will presume as you say it is the touch 2 and I look to doing the update 👍🏻
Brilliant thank you.
From your experience is the update worth it? I like the idea of the more modern interface it seems to offer.
plus many roads are currently missing of my map.
Also does it matter that my software has a W in it but the update doesn’t? 😆
No the W won't matter it refers to Western EU map set however as you are purchasing through Toyota GB you will automatically get the W version.
Thanks very much 👍🏻🙂
It's worth it for the updated maps. The interface upgrade I don't recall being an amazing difference but I am one of those that likes to keep things updated. There were some issues/bugs, fixed by the later versions (well, majority of the bad ones) so as long as you are getting the latest you should be good. I think "Aha" music and Coyote were part of the newer software - Aha I liked the idea of as they added Amazon music integration to it but I was never able to get it to work. Coyote I found just odd and never bothered after a few attempts on the free trial. Zero documentation, even thru google.
The other bit for me was having the traffic updates and camera updates, both part of the "map care" which on older Auris was only 1 year, so I did a 3 year map care when that ran out and that includes map and software updates, with traffic and cameras for the entire period.
Bottom line, for me at the time, it made sense and was worth cost. The 2018 Auris I bought a year or so later had 3 years mapcare as part of the new package but I didn't lose sleep over wasting a year or so on the 2015.
  • 5 weeks later...
I have a 2016 Auris Excel Hybrid. This is my head unit. It’s a Toyota Touch 2 with Go.
Version 6.12.0## is the last version to include bug fixes version higher e.g 6.18.0 ## are just newer maps there are no additional fixes, here is the list off fixes since your version.
Additional phenomena reported since software release version 6.7.0, 6.8.0, 6.8.1, 6.8.2, 6.9.0, 6.10.0, 6.11.0 and solved in 6.12.0 L/H.
  • Improved voice instruction in Czech language by improved grammar and vocabulary.
  • When a phone call is made using the phone controls instead of the steering wheel controls or the soft keys on the display the navigation screen blacks out when the front camera switches on.
  • Units installed with 6.11.0 L/H from factory will not set the First Use Date (FUD). For more details see TSB BE-0064T-TME
Additional phenomena reported since software release version 6.7.0, 6.8.0, 6.8.1, 6.8.2, 6.9.0, 6.10.0 and solved in 6.11.0 L/H.
  • In software release 6.10.0 the country information screen pops up after ignition on without crossing a border.
  • Correction for spelling mistake in Danish (parkering was written as parkring).
  • USB with music files is not recognized and no playback is possible.
  • BT function is sometimes not working after ignition on. Next ignition cycle BT is working again.
Additional phenomena reported since software release version 6.7.0, 6.8.0, 6.8.1, 6.8.2, 6.9.0 and solved in 6.10.0 L/H.
  • No audible warning beep anymore when approaching a speed camera
  • The country information screen pops up even when driving in the country without passing a border.
  • Czech language voice guidance improvements.
  • Reset during updating the map database.
  • After inputting a destination (> 150 Km), the system freezes (only in 6.9.0).
  • At low speeds (front camera is on) and while using hands free, the display blacks out.
Additional phenomena reported since software release version 4.5.0, 6.6.0, 6.7.0, 6.8.0, 6.8.1 and solved in 6.9.0H.
  • In release 4.5.0, after pressing F, France is not listed in the country list and when pressing the map button, the system resets.
  • Letters specific to the Polish alphabet are not or improper displayed when listening to DAB radio stations.
  • Letters specific to the Icelandic alphabet can't be selected.
  • Copy / update algorithm is improved to improve update stability.
  • In release 6.7.0 the DAB radio text is briefly displayed, then disappears.
  • In release 6.7.0 the DAB radio text of another station is displayed.
  • In release 6.7.0 the screen blacks out after ignition on after previously a USB stick was inserted. This phenomenon is present on vehicles with F-ten display audio only (Hilux, C-HR, Yaris).
  • In release 6.7.0 continuous beeps can be heard when approaching a speed camera.
  • The last played music track is not retained when playing music using an I-pod.
Phenomena reported since software release version 6.6.0H, 6.7.0H, 6.8.0H, 6.8.1H and solved in 6.8.2H.
  • Playback of music on USB media stops a few minutes after ignition on.
  • Track up / down function is not working during music playback from a USB medium.
  • Mirai only: Image of the rear view camera is displayed when shift lever is in drive ("D").
Note:
  • The listed phenomena are only occurring on the high version of the navigation software.
  • For "low" version, 6.8.1L remains the latest released software version.
Phenomena reported since software release version 6.7.0 and solved in 6.8.0
  • New set of voice guidance instruction in the following languages: German and French
  • Long city names can't be inputted because the text field to input city names is too small for the captioned city.
  • In Finnish, Greek, Russian and Ukrainian it's impossible to add a phone n° to the favourites list.
  • On Camry, Hilux, Yaris & CH-R the display may blackout with a USB media device inserted.
  • Correction of postal code errors in the UK.
  • Wrong road name (previous road name) displayed after an intersection.
  • No USB media device is inserted in the USB slot but the media screen displays that the USB media is loading.
  • Improved copy error algorithm to ensure data integrity during update to 6.8.0
  • Correction of spelling mistakes against the Danish language.
Phenomena reported since software release version 4.5.0 and solved in 6.7.0
  • In-operate data connection for weather, fuel and parking app in 6.6.0 only.
  • Wrong ZIP codes (Hungary) in the map database
  • Arrival time is one hour ahead of the expected time after switching to summer time (Russia only)
  • Wrong colour for highway boards (Swiss)
  • In the map setting menu "block road ahead" the menu field are partially translated in Czech.
  • In UK, the search function for postal codes doesn't allow to input the full postal code for some postal codes.
  • The audio source is changed from FM / AM to USB after ignition off / on cycle.
  • The license key is requested to update a "High" version when the vehicle is still covered under the free map guarantee.
Phenomena reported since software release version 4.4.1 and solved in 4.5.0
  • After switching to wintertime the arrival time is one hour ahead of the expected arrival time.
  • Wrong pronunciation in Czech, Slovak, Hungarian and Romanian of the voice guidance command: "Please proceed to the highlighted route"
  • The audio is playing (normal condition) but on the screen it is mentioned: "Audio off"
  • Sending BT audio streaming commands to an I-phone via the steering wheel commands is not functional.
  • Improved installation stability via official USB media to avoid map update failures.
Phenomena reported since software release version 4.3.0 / 4.3.1 and solved in 4.4.1
  • In Danish the warning message for internet roaming is displaying a mix up of Danish and English words.
  • Language specific characters for Danish language included.
  • In Portuguese 800 meter is pronounced as 200 meters.
  • Improvement of street name pronunciation in Switzerland.
  • Impossible to register extension box on customer portal because of wrongly device ID.
  • Display blacks out after ending phone call while shifting out of reverse.
  • Bass – Treble – Mid amplifier settings reset to zero after ignition OFF / ON cycle.
  • Visual reset of BT audio volume to zero after ignition OFF / ON cycle.
  • 2 years later...
I just got an update for 6.22WL, Map update 2023v2 that stated 2022 fall map.  The year number is 1 y later than the actual map. It cost €36 with coupon from online seller.
The map is from
1. Link for download.
https://mapupdatecontent.toyota-europe.com/Updates/Toyota/CY16_6.22.0L_EU_^CDjRmLUkq4CQVj8*/6.22.0L_EU.zip
2. Extract the files to the root of usb2 stick. Wait until it ask for code and send the picture to the seller (Toyota dealership or online seller)
3. Update for about 30 minutes after code is inserted
20240103_172623.thumb.jpg.f72fdd8c9429b41b65ce08a140554312.jpg20240103_171230.thumb.jpg.9c2dd4b02e8608a6bc6484a5f9900f03.jpg
