Speed Indicator not working in my Yaris Hybrid
Logantoo
Yaris Hybrid 2019
As a new member I hope I have posted this in the correct place. I changed the time on my Yaris only to find I must have also done something else as the speed indicator no longer shows up. This is important for me as I use it in preference to the main speedo. If anyone can help me, as someone who is not very technical, I shall appreciate it.
Many thanks,
Logantoo
Moved to the Yaris/Yaris Cross club.
turn the car on, press the return button, so it displays the menu and scroll down/up to find it
Thanks, but this is where I feel stupid, I have done what you suggest but can find no mention of a speedometer on/off.
It's not an on/off thing. It's just one of the 4 or 5 displays you can select to show in the centre. You must have accidentally selected another so need to scroll up or down to get back to the speed.
Just been out in mine and checked this.
If it's the same then do not press the 'return' button on the right of the wheel. Above that is a control pad with up-down, left-right arrows and a centre button. With the car on just use the up-down buttons and this scrolls through the displays. On mine the digital speed is between the traction power display and a blank, but there are several others.
When you first turn the car on it puts you in the menu after 10-20 sec it goes into display mode
I'm sure there is a vid on YT
Many thanks everyone, it now works, its nice to know so many of you are willing to help. Thanks again.
Logantoo
  • Like 3
