Idle rattle
Impredatle
Hi al!
Recently bought a beautiful T25. Unfortunately the car started rattling when idle, so I am dying for some ideas/suggestions because I cant seem to figure it out myself.
As follows:
- Noise only appears for a few seconds (4-5)
- Only occurs when RPM's drop from a higher amount to idle (~700 RPM)
- No other complaints regarding the engine
- Noise goes away when revving +1000RPM. And immediately comes back when reaching idle RPM
- Oil is fine (level that is)
- Possible correlations: AC got filled up, used the wrong gasoline (E10) switched to E5 now
- Noise appears to be coming from left side of the engine, equally loud top/bottom
My own guesses: AC clutch, loose heatshield etc., Seems to be a very distinct sound that I cannot compare to any examples I have found online
And of course videos, because how can you diagnose something without the noise itself.
Any suggestions/ideas and Ill be right on top of it to try it out!
Thanks in advance
23 hours ago, Impredatle said:
Hi al!
As follows:
Thanks in advance
Mines was the AC Clutch.
Thanks!
Was the sound the same?
And did it matter if the AC was on/off? Or was it always there.
