Hi All, powered side sliding door not opening with keyfob or handle or button on ceiling no idea why, any help would be great thanks, im getting a beep when i press the button on ceiling to try open it
Can you unlock and open from the inside?
Couldn't open from the inside at all, child lock was not on either, its working again now but very strange.
I experienced a similar thing about a week ago. The rear passenger door would not open when the internal latch was used. It would open from the outside or when using the button at the front in the headliner control unit. I also noticed that there was a little yellow light in the unit that lit up - it was quite dim so I only saw it while driving in the night.  After about a week and a bit, this past Sunday, the light had gone off and the door could be opened up from the inside!
So like you, I'm none the wiser as to what the issue was / could be.
Hopefully an expert on here might know.
Cheers.
On mine thre is a button to switch of the power, just to the left of cigarette lighter, easily knocked.
