blown fuse
laco
Hi all,
I had my last question here regarding fixing alternator on 2nzfe (yaris verso 2005) but forgot login 😀
Today I purchased new rectifier and installed on broken down alternator,thinking that this was main  issue.
As soon as I plugged Battery after installation of "repaired" alternator, Ive blown a fuse not even starting a car. After I started a car and alternator doesnt charge (car starts, dashboard, radio,windows central locking and no electrics works only headlights not even reverse or breaklights)
After thinking this must be the  alternator regulator problem, I have put my new Denso alternator in and see that it also doenst charge.
What did I do wrong? Why isnt new alternator charging if it did before ive put "repaired" one?
Hope I didnt reck something expencive.
Any tips?
The old alternator is junk, it's more than likely got a fault on the windings - I don't understand why your messing about with it
New denso doesn't charge and you have killed the electrics
You would have killed major fuse(s) check the fusible link Block (Part of the positive Battery terminal) the fuse links are about £3 each
1 minute ago, flash22 said:
You would have killed major fuse(s) check the fusible link Block (Part of the positive battery terminal)
I'd think the fusible link would kill the headlights which he says are working.
It splits into 3 - Power 60A, Alt 120A and ABS 60A
https://knigaproavto.ru/shemy/en/toyota/echo/1063-toyota-yaris-verso-amp-echo-verso-fuse-box-diagram.html
At least you can swap out the flat fuses, The Aygo has an issue with the 120A Alt fuse blowing under some conditions it was replaced with a 125A,
I know, stupid me, shouldnt have played with it.
But thanks gents, will check fuses tomorrow.
Hope i didnt blow something more important, but I guess not if car starts.
Fusible link near the positive Battery clamp. Never, ever meddle with a starter or alternator without disconnecting the Battery before.
thanks for advice, Battery was disconnected, just right after conneclting it back, it blew something...hope fuse
it was 120a fuse ..all works like it should now .. not gonna mess with old alternator, I believe flash22 that it can be also regulator or windings... thanks all for tips
