TPMS module location verso 1.6 d4d 2015
Hi.
I need help to find tpms module in toyota verso d4d  1.6 2015.  I want to make tpms light bypass but i dont know where to find module.
Can anybody help?
What country are you in ? Do you have any sort of vehicle inspection ?, you can't simply bypass the light the tire pressure warning ecu talks to the instrument cluster over a data line and it self-checks every time you turn the ignition on
scan for codes and find the actual issue, its more than likely odd tire pressures, a bad sensor or flat sensor Battery
I found some theory on Internet to fix this annoying lamp , and i  wish to check ,is it working.
 Only want to know where i can find this module on this car.
It's in the rear left 1/4 (driver's side for a LHD car)
If you are in the EU it's a legal requirement after november 2014*
Disabling the TPMS or disconnecting it will put the tpms light on, it may also put on the EML on
  • 1 year later...
Hi.have you sorted your issue?
Just have same problem computer showing TPMS module fault and can't find where its located.
Would you advise did you find your module?thanks
