Electrical issues
Steve Simler
Hi
Had my Yaris since 2013 with relatively no problems - till a couple of weeks ago. After filling up a petrol station, turned ignition key but nothing happened. Tried zapping the remote which did not even flash the side lights. Tried in vain with no success and called out the AA. He was equally perplexed and checked the Battery (the standard not the hybrid one )and it gave a good reading. I think he said it was over 7 volts which should be enough to start it Then sudden all went back to normal and it worked ok - he said get it checked with your usual service centre.
A service was due so booked it in and all the service was completed - and the mechanics said Battery was fine. A few days later the same thing happened again.
Went for a long journey and after just leaving the vehicle for less than 20 minutes.   No response from remote fob (and before you ask put a fresh Duracell Battery in). Also tried second fob but the same. Had to unlock door manually and again put key in ignition and nothing- but noticed the malfunction lamp flicking and a clicking sound. And again after a couple of minutes turned key and all works
Have tried to recreate the error but to no avail. Has anybody had something like this before?
The Battery is dead/dying 7-10 years is about right for an 12v AGM Battery assuming it's the original, lockdown has taken its toll on batteries, borderline voltage will play havoc with the electronics
Toyota Part number
28800-21181 (Yuasa S34B20R)
or
28800-YZZPC
https://www.ebay.co.uk/itm/224628086547
the compatibility listing is incorrect on that listing
Note. The right-hand Negative terminal
if you have off-road parking, you may want to invest in a Ctek or a decent AGM charger
Moved to the Yaris/Yaris Cross club.
29 minutes ago, Steve Simler said:
Thanks guys I will see if they replace under warranty
What warranty? Can’t see a warranty on an eight year old Battery. Maybe I’m missing something.
I was being flippant - when I got it serviced by Toyota and as it’s less than 10 years and 100,000 miles,  they told me I get a one year extra warranty. And at the service they reported my Battery as Ok - so not a historic issue - I will chance my arm and ask  when I take it for its MOT in December 😎
2 hours ago, Steve Simler said:
I was being flippant - when I got it serviced by Toyota and as it’s less than 10 years and 100,000 miles,  they told me I get a one year extra warranty. And at the service they reported my battery as Ok - so not a historic issue - I will chance my arm and ask  when I take it for its MOT in December 😎
You may have misunderstood. When you service with Toyota they do a health check on the Hybrid Battery and give you a 1year warranty.
Thanks Catlover - I still might make a cheeky offer - my service bill was £900 - brakes and tyres!😎
  • Haha 1
Absolutely, nothing to loose, a 12v Battery to gain..
  • Haha 1
IIRC it will be £200 fitted, the Battery is not tested it just shows a voltage in techstream so come up OK - voltage can be fine, but the Battery looses it current storing capacity
