oil light
chic.hill
Hi.
My oil light came on when the engine temp reached normal on my 2004 rav4 D4D. Suspect oil level sensor so ordered and when replacing found a broken wire on the sensor plug, the wiring was that brittle it had broken in the sleeving soldered new wiring all is ok now.
Chic
Moved to the Rav4 club.
1 hour ago, chic.hill said:
Hi.
Chic
be sure the contact is firm when heated at working temp. it must be ok if no alert as an oil light
