pwr heat does not work
tico740
hi, i am new here, I have a question for toyota auris 2007 1.4D
PWR HEAT does not work, when you press the button, rpm go to high, but there is no heat as if the heater is not working
did anyone fix it?
where it is installed?
I apologize for the broken English
Have you checked the fuse and relay, can you hear it, is it getting fuel ??
no, I haven't checked the fuses yet, I haven't thought about it, I've never opened the fuses yet, thanks for the suggestion,
no i can't hear it, how do I check if he's getting fuel?
hi, i check the fuses and they are all alride, i didn't find the heater relay, i was already at the car electrician, he told me not to watch these cars and i was at the original service they told me about 180eur to diagnose the problem
I think I settled the matter: P
  • 2 years later...
Hey, did you find the cause of the issue? My Yaris D-4D's power heat doesn't work and the button doesn't light up when I press it. I'm going to replace the fuse and check the relay but would be nice to know what your issue was.
