Key fob battery
Annac1988
I bought a Toyota Yaris 2007 a few months ago with a keyless key fob. This week it wouldn’t unlock the car or switch on the ignition so I used my other key fob which worked fine until yesterday when it wouldn’t work either..
I figured it was a Battery issue so replaced batteries in both key fobs. However, when I press the unlock button now on both key fobs and won’t unlock the car or start the ignition.
Any ideas?
Replacement batteries faulty or incorrectly fitted perhaps? Some key fobs have a red LED that flashes when you press a button.  If yours have the LED that will tell you if the Battery is OK.
