Need a CD player.
Marion Aitken
it's like sticking 32 gb of ram in a pc and the bios only sees 16gb of it, the processor is an ARM dual core at 800 - 1 ghz it runs QNX RTOS what is a Linux kernel at this point is based off 15+ year old tech
but it does support FAT32 and NTFS that shows it's a limit of the OS
Wait wait wait, do the Toyota headunits really support NTFS?? Do they support junctions/symlinks on NTFS too???
That would solve my multiple-copies of song in different folders problem!!
Not sure what menu it was in, it may well have been the sat nav, it's not turned on as default
Just received my Bus Pirate today, so i need to figure out how it all works, then have a play
Again from the manual for the Touch 2 Go in my 2015 Avensis, the supported file systems are FAT16 and FAT32 only.
13 hours ago, Stopeter44 said:
Is the art work "loaded" into each song. You can integrate the artwork into an .mp3/.aac file.
yep the art work comes up with each song.  its  when i have my albums up instead of listing each album i rather have a albums pick like itunes so can see what want to play hard to know what each album is
13 hours ago, flash22 said:
Artwork is a known issue with the touch2, it works fine with the nav tho
It's not the size, it's the amount of files
il have to see the way i have my memory stick loaded is i have made folders which are named the albums and the songs are in them tbh there are loads of folder albums and the toyota headunit sees all the alums on my new  128GB Corsair Flash Voyager Slider X1 USB 3.0 Flash Drive from the corsair i got.
