Third brake light wiring - 2014 Yaris hybrid
Th3C10wn
I've just discovered the third brake light on my 2014 Yaris hybrid has died 😔, as a quick fix I have some red led strips that should be easy to get in the plastic Shell and provide exactly the light required (and give me a bit of time to cry about the 95 quid a new light is gonna cost).
The bit that I'm worried about is the connector for the light, it has a white wire with a black stripe and a blue wire.... Reading up on toyota wiring I'm betting blue is my positive but was wondering if anyone can confirm this before I do some damage as I've read that the wiring in Toyotas can be a bit all over the place at times.
Use a meter, white/black is ground, you can pull the lights apart, but typically they do not fail all at once, i would check the voltage to the plug with the brake light on, then check the resistance of the ground between the plug and the tailgate ground (by the wiper motor) then the blue between the plug and the tailgate harness plug behind the rear 1/4 and/or c pillar trim
Cheers for the fast reply. I did think it was odd for the whole strip to go at once but I'm not very clued up these. The person who pointed it out did mention it was flickering first before going out completely so maybe an electrical issue somewhere that may require getting it into the shop 😕
