Cvt gearbox
Danukas
Hi ,
I need someone's advise . I have Avensis t27 2009 ,1.8 petrol . My automatic transmission got damaged and try yo change to other . Accidently bought newer model gearbox . Everything  fits perfect but there is a problem , newer version of gearbox does not have extra sensor and connector is different... any solution how to fix , or I have to get new gearbox ?
I think there are two options, but you need to be careful with what you do! The first option would be to see if the bits on your old gearbox can be swapped over to the replacement unit. The reason you need to be careful, is any change might not work, due to minor compatibility issues. Second you need to return the replacement unit back and source the correct year gearbox for your car.
There are a few sites like toyodiy.com or 7zap.com, that you can check the part numbers for you particular car, so you can get the correct part. You need to sign up with toyodiy.com to see the diagrams.
I am  not an expert on gearboxes, but know the hassle of getting the correct part to fit and work properly.
