Rubber squking
Aj. S
Hi I have toyota avensis 2012 diesel d4d estate tr. Does anyone had problems with doors moving when you drive over ruff surfaces like rubbers are squking? Any suggestions or who had them problems!
Open the front doors and check inside the door opening where the door hinges and the check straps attach to the body. Any cracks ?
Mine has always done this to some extent. I occasionally spray the door seals with some silicone spray lube which helps to quieten it.
  • Like 3
I had a similar problem with the rubber seals making noise - I just cleaned the rubber door seals and it cured the problem
I had this same problem too. I cleaned seals and used silicon stick to them and it cured that.
How do I clean them?
Just use wet wipe, towel, paper towel or something like that. I didn't use any chemical to clean those seals, only water.
I just cleaned them with window cleaner and a cloth when I was cleaning the windows
